Has anyone just cut a piece of 4mm metal sheet to make it a back wing ?
+: Cheap, easily available, stiff
—: rusts in any water
The cheapest alternatives are rectangular sections of G11 (FR4 G10) flat bars sanded down to dimensions. Sanding carbon flat bars = nasty dust.
Worth a try: carbon fibre fabrics (not so expensive) + resin applied with a brush around a thin 3D printed core (airfoil section Eppler E817).
ebay or sites like http://www.fibermaxcomposites.com/shop/carbon-fabrics-c-36.html?language=en
That’s just a blunt knife
don’t use metal. Use a composite solution.
You could take a cheap skateboard deck and cut it to the right shape and do a bit of sanding. Then coat it with some fibreglass.
Yes you are right. We eventually go for a 10mm G10 plate, rounding the edges
