Good Day to all,
First of all I would like to thank you all for your valid input to find in this forum. I enjoyed reading some expiriences and this brought me to my 1st result. I share some pictures and technical details. With the video can see the foil in real.
I am a foil wind and wingsurfer. The E-Foil was a winterjob last winter I will build more E-foils and will improve some technical details during coming winter.
E-Foiling brings to you to another horizon and is really amazing. You can go almost anyware without distrurbing nature or people!
Components: Motor Maytech 65162 - 120KV
Controller: Maytech MTSF300A-OPTO
Remote: Maytech MTSKR1905WF
Battery: 13S10P 48v 35ah battery, samsung 3500mah cell, 100A BMS
Front Foil: 72Cm Fuselage 74Cm Rear Wing 37 Mast 70cm
Board: Modified F2 Air (was 115L) now 85 Liter
Initially I started with a duct for the prop but found out that this was a power decrease of at least 30%. (As all surfers know, one piece of seagras is already enough to give you the impression if somebody pulled the handbrake.)
I foil on 60 to 70% of full capacity and reach between 45minutes and 1 hr.
My watercooling needs to get improved as I need to put wider tubes in my next project.
The volume of the board is more then enough once you pull the trigger and come to 5km/h of speed.
The battery box has been purchased external. the battery factory installed it for me.
