Hi there guys coming to you from New Zealand,
I recently finished my build on an electric longboard and have been dreaming of an Efoil of my own for awhile. So, being a student I have begun to conceptualize ways I can have both cheaply and, effectively. It looks as though, the 10s battery and, VESC I have currently installed on my Eboard would work well -  and therefore, I plan to create a swap-able system wherein the batteries and VESC can be easily switched between the two. I will be going to uni next year, and will have access to a million dollar metal sls 3d printer among other things. - therefore,  this thread will be updated as I go along with my build. I also wanted to ask if a 190kv Eboard motor at 2500watts peak - Electric Skateboard Motor 6355 190KV – DIY Electric Skateboard , would work on an Efoil just in terms of power output with the correct gearing ratio (I understand the cooling problems with an out runner)- sadly from the research i’ve been doing it looks like it wont be powerful enough, therefore, what kinda power output should I be looking for?
Also, would love to hear from anyone working towards a similar goal  .
Big thanks to pacificmeister for everything in regards to the Efoil community.
