Hello,
I would like to separate the rotor from the stator for the first time after a treadmill run. I removed the locking ring and the washers. However, I can only pull off the motor by about 1cm. Then it somehow clicks into place. It definitely won’t go any further out. Even WD 40 doesn’t help. Does anyone know this problem?
I would be grateful for a tip.
But this motor is brand new. I just tested it in a water bucket. So normally the motor must come out much more easeliy. Or does it often happen that the rotor cannot be released, even when the motor is brand new?
There may be several reasons. For example, a slightly riveted shaft, or a bearing crookedly seated in the seat, or you have strong magnets). Just use the tool.
