Hi all,
after some reasearch I have decided to build an efoil.
First i have made templates for hot wire cutting. After that hand shaping.
When joining foam blocks I’ve used too many pu glue and had a problem with wire cutting the bottom. It stopped on the spot and made a big hole that i had to deal with later.
Fairing is done with microbaloons and epoxy
The board is 152 x 60 x 12,5 cm, still only in foam.
Rene, what do you call your new stab? This one looks good! My all time favourite is still your 1150 and fuse, but with fliteboard stab.
Also your mastfoot needs to be redesigned for better mast support. 15mm is not enought for heavy guys…
We are not RENE… But the efoil wings of rlboards work very well…
The new inflatable efoil volt-efoil is now hitting the market…You can test it with us soon.
I need your experience. How does your rail boxes hold the forces ? I’m planning to fiberglass thoses aluminium bars in my board but i’m worried about the resistance. The worst scenario would be for them to come off the board and rip all the fiberglass above off of them…
Pouring the seal.
Decided to put the seal on the bottom and arround the hatch lid.
I’ve made temporary fences that were held by the clay (white). Contact of the fences and box was temporary sealed with plasticine.
On the top of the fences i’ve also put plastecine so that it made impossible for the silicone to run over the fence.
