Hi everyone and greetings from Romania, I have completed my first successful flight (on my knees) and I thought it’s time to share my build. A big thanks to every one of this forum sharing their designs.
Foil: Gong V2 85cm Mast and Fuselage, Gong Curve XLT front wing, Gong Curve XL Stab
Board: Gong Hipe First 5’5
Flipsky w7 Water sport Kit:
Motor: Flipsky 65161, 12mm, round with thread, 120 KV
VESC: 75200 Pro V2, with Bluetooth and Power Butoon
Remote: Flipsky VX3 Pro (I messaged Flipsky and I payed 15 USD extra to upgrade from regular VX3 to Pro, at the time of the purchase it was not available in the Kit)
Flipsky Metal Propeller cut down to 140mm diameter
Waterproof box: Auer CP 4316
Battery: 2 Lime E Scooter batteries (second hand) connected in paralel + 250A BMS (JBD SP22S001 6-22S NMC). BMS is used for both charge and discharge
Charger: currently work in progress (borrowing one)
Various stainless steel nuts, bolts, washers, cable organizer and straps from Aliexpress
3D printed parts for motor mount, propeller protection, and top plate
I drilled the mast and routed the wires through it, I have also drilled the top plate and I have added a 3D printed top plate extension that allows me to direct the wires to the back after they exit the top of the mast. I have also added some cable guards where the wires enter and leave the mast
Photos here:
A very important lesson I learned is that when configuring the controller you have to have it set to H (high) otherwise the motor will cut out at full throttle.
Another lesson learned the hard way is to wear a full face helmet for the first sessions
Here is the final build:
