Efoil electric surfboard kit practically brand new! $6000
Only used twice electric surfboard. Yakima Carver 2 efoil used for hydrofoiling. Fly over the water at up to 18 MPH! Dimensions are 5’3” long and 28” wide. Ride from 70-90 minutes per charge. Comes with waterproof remote control.
Front Wing: Kujira Helium 1500 cm² full-carbon
Rear Wing (Stabilizer): 178 cm² carbon rear wing
Propulsion System: 3–4 kW motor with a sleek, low-drag aluminum propeller
ESC (Speed Controller): Mini ESC that’s lighter, more efficient, and helps extend battery session times
Battery Specs: Compact 43.2 V / 35 A lithium battery, quick charging (~4–4.5 hours), visible charge level meter
Would you part out just the motor, motor mount, mast and wing?
Yes I would do that, send PM
Its amazing how many names and genders you have…
