It starts in April.
I did my first test last week.
I succeeded.
The speed of gps was about 25 kilometers.
It started with 55mm impeller waterjet type, but it had a thrust of about 20kg.
The water jet type has been changed to 120mm with a 5:1 deceleration.
Great work! So what made you switch to the bigger prop and gear box
What an interesting build. Thanks for sharing! Was that your esc that burned up? If so which model was it and how did you solve that problem?
Great work! Thank you for the pictures!
