I’m just starting in the eFoil topic. But before I even start building I’m already facing one problem:
On the lakes in my area only electric vehicles with max 4.4kW are allowed. As far as I have seen eFoils normally have more kW.
Can you tell me:
Is it possible to build a eFoil with only 4.4kW?
Does someone know a motor which would match this?
sure it is possible. On my lakes is the same rule.
With a 63100 motor and a Gong Rise or Pro wing in the M-L or even xl range (depending on your weight) it is easily possible.
I drive a Gong Rise M so far with 63100 motor and 12s battery and for takeoff I need around 3-3,5kW. When you are flying it something between 1-3kW, depending on your desired speed.
