For our senior design project my group is building an electric surfboard and we’re having some trouble deciding which parts are best for our situation. Our goal is to move at around 2 m/s to assist people catching waves. Our calculated required thrust is 172 N. So far as a propulsion set up we have the following:
Jet drive- MSQ 50 mm water Jet thruster with CNC 7075 2 Blades prop
Motor- SSS motor 5694 1000 kv
Battery- 6600 mAh 6s 12 lipo pack
ESC- Turnigy Marine ESC 150A
Will these parts work together effectively? We know lower KV allows for more torque but how low is to low? Our motor has a max current of 258 A, if our ESC is rated at 150 A are they compatible? Is a single battery enough to support this motor to full capacity?
Any answers would be a huge help. Trying to ask these questions to manufacturers has left me empty handed or left with vague answers.
