I am not sure about how the Flier ESC works and should be wired, but normally you try to avoid loops at all costs (e.g. @MaxMakerfried a VESC by a 5v and GND loop) . So I would check if the Flier ESC needs the 5v and GND at the PPM input (wiring diagram in the manual). If not, only feed him with the signal cable.
Concerning the breaker it is the one:
So I’ll do like my MTB and place it at the junction of two lipo, as you advise me @Alexandre.
I note everything and would do a schema to the standard.
I think you can wire the htrc to sbec to save memory when the kill switch is activated
Be carefull , my wattmeter was getting to hot in my setup to be a permanent installation
My circuit breaker as well , it was pretty hot after 20min of riding , but it never went on (200a)
You can leave it here , but you have to plug to the sbec (on a small plug on the side if it has one) in order to keep the memory when the kill switch is activated , or you can put it just after the lipo alone
