Engine mount stl
Hello friends
I want to print an mount to my engine (6530 180kv)
Does anyone have a stl I can use?
The engine dimensions are attached in the picture Of course I also need a propeller
motor info
thanks!
You’d probably like to say what mast you’re going to mount it on…
I still haven’t decided on which mast, is it critical?
I’d love to get something initial just to check
How can I say…
Just a thought…
The motor mount is between the motor and the mast, making a connection between them. You yourself, give a drawing of the motor. Great. He is on one side.
And on the other side, what is there?
Joking aside, there are many different motor mount solutions on the forum.
I don’t remember exactly your motor, but do a search. Some sizes may match or require minor modification.
And one more thing… are you sure this motor can be used in water?
Good luck.
Thanks for your help
It’s the engine
I would love references to STL files because I didn’t find unfortunately…
In my opinion and experience as an RC pilot, this is a great engine for an aerobatic RC airplane.
My advice, if you allow it, don’t ruin it.
Buy a cheap 6384 or 63100 motor from Aliexpress and start from there.
The forum is full of wonderful and detailed descriptions of how to do it.
Good luck.
