Erpm 65220 Fliteboard prop
Just a FYI
I did several trial and error runs, but came up with 10,000 erpm with 80% limited start limited top speed to 20mph. axis spitfire 960 front wing, skinny 35 tail 220lbs rider
I was lowering my erpms so when i breach motor out of water when in foil assist mode, the prop isnt spinning crazy fast compared to actual speed.
quick q on erpm, what is your calculated mechanical rpm?
do you divide by 4 (default config for pole pairs)?
i’m trying to troubleshoot why my setup is moving so slow. maxed reading today at 3700 erpm pulling 120A…
I think for erpm you can even just list an extremely high nuber like 99.999, that way you can be sure this is not the problem
