New to this forum!
I was just hoping someone could help me with some issues I’m having with the pair of flier 400a Boat 16s escs I have.
The issue is basically that the motor judders and can’t complete a full turn when throttle is applied. I’ve read up online and youtube that it could be caused by bad motor connections and bad battery connections but they all seem fine to me…
I’ve attached images of all the connections I’ve made but it seems there may be another issue. Im starting to think that maybe my TX isn’t compatible with it, its a HGLTECH 2.4G controller?
Also could anyone tell me if I NEED to use both battery leads as currently I have then joined together to formne cable to the XT90…id like to minimise the connections I need.
