New to the forum, but I have been doing some research into building my own efoil set up. I am hoping to get some opinions on an idea to put the ESC and receiver in the nose cone of the motor mount, with an extended antenna running up the mast and into the board to get signal to the remote. This would allow a simple watercooling circuit to service the ESC and the only electronic that need to be in the board is the battery. Has anyone tried this? Any immediate issues anyone can see?
Flipsky makes a motor with the ESC built in you could use that this would be simpler. I like the ESC on top of the mast plate that’s what I did on my build it’s a perfect fit for the Flite boards it doesn’t need cooling stays cool it minimize the wire length and lower the swing weight at the end of the mast.
I can tell you that the battery cables being too long is not an issue and i really like the idea of having the esc in the cone - totally doable! I would do the same in my build.
Esc plus and minus & signal needs to run to the battery in the board and signal reception is fixed
It’s Flipsky 75200 with the waterproof enclosure. I unscrewed the water cooling plugs and bolted it to the adapter plate that converts the regular Gong mast to the Flite board mast socket.
