ESC throttle issues
Hey I have issues with one of my ESCs. My setup is 18s battery to the ESCs and then to the motor. I’m using a flier esc rated at 18s or 20s, I don’t fully remember. But a while back I was testing the ESC and I had the ground cord connected and the power connected but at where to connection happed two wires touched and shorted. After this that ESC has been doing this weird thing with the throttle where it reads it but scrambles the input. Where 0-30% throttle is 100% power and 40%ish is 0. Could my ESC be broken and do I need a new one or is there a way to fix this. I have tried programming it many times with no luck and the receiver is wired to both ESCs by splitting the signal. No burn marks or weird noises are being made by the ESC. Could anyone help with this issue? Also the other ESC works completely normal with the same signal.
