Aloha good folks!
At the bottom of my soul a new dream has emerged and now it’s time to do some brain work to fulfill it
I’m thinking of building DIY jetboard or rifle-case efoil. Jetboard is preferred because of the feeling and shallow waters capabilities, but I guess it would be a way harder to build comparing to a rifle efoil.
But. First things first.
I have a decent esk8 gear and I wonder if the following can be sufficient to be utilized in a jetboard:
2 X 6374 170kv 3500kW
MakerX dv6pro dual vesc 100/180a
12s7p LG MJ1
I have an idea to make some gearing so the both motors would power one jet prop - so there would be some room do adjust ratio/kv/rpm/torque.
Do you think that such a setup can provide any decent speed (like 20kmph at least) and reasonable working time/range? Or it’s just not worth to convert my esk8 and more powerful battery and motors is the only way to go? My weight is an advantage here (65kg).
I’d like to achieve min. 20kmph+ (40-50 is the golden goal ) and min. 30 minutes of fun (60 Min is the goal). Possible?
I have tons of other questions, but let’s deal with this one to start and then I’ll spam with other topics
Shaka lads and gyals!
