Eve 26V 18650 Battries - usable current
A little unclear about how much usable current I can get out of these batteries. Details of battery is:
Max Discharge Current: 7.5 A
Amp Hours: 2,550 mAh
Datasheet talks about a discharge current of 0.5 Amps.
I am chasing:
Start up current: 60 Amps
Running current: 30 Amps
Proposing a 10s12p, so batteries will be pulling 2.55 amps continously for 1 hour.
Does this sound reasonable or would generate a lot of heat ?
Thanks in advance.
It will not be an issue if the heat can be transferred away.
For the heating you can use this calculator:
https://lbre.de/BPC
