I bought the cheap waterproof Remote and thinking about how I can extend or change the normal antenna cable from the receiver.
In this picture you see the soldered antennawire.
#Aliexpress € 1,35 | MMCX-MMCX Verlengsnoer MMCX Male naar MMCX Vrouwelijke RG316 Adapter Coax Pigtail Kabel https://a.aliexpress.com/_dZFRuLg
Cut it near one of the connectors. Solder the short end to the receiver en use the long end in your board as antenna cable. You have to cut the shealding on the antenna cable to ~30mm for it to work on 2,4ghz.
maybe a little bit but it’s appairing system the frequency can drool a litle just need the cutting the good lenght of 31mm for 2,4 ghtz and in this post the rx haven’t the extremity cut of 31mm i have the same if nice2cu can post a pics about all the antenna lenght so the little chinesse don’t worry about the frequency tune
Old post but I was searching for answers rather than just asking. My Takuma antenna consists fo a long piece of antenna wire. I am suspicious that it is causing my remote losing connection. where it comes ouit of the esc is a 90 degree fitting then some broken insulation. Looking under the insulation I note that the shielding in not connected to the 90 degree elbow (not grounded?). should it be? The other end of the antenna had a small bulb on it but that is missing. I assume the shielding and the inner core should be insulated of one another. Is that correct? I am quite copnfused about the shielding. I assumed it was designed to create a gausian surface around the inner cor so that one can extend the antenna without affecting the “tuned” length (30cm?).
