No coating on the board under the black foam of the induction plate
Bms of the lipo isn’t coated , I order some lipo so I can easily coat the « bms » before silicone it …
first test in November
On my box it said v4 , may be version ? The lipo terminals are silicone , I don’t if the « bms » was on the first model …
I did all three coatings one after another. First Plastik70 then PlastiDip and then CorrossionX. So it’s not quite clear if the water barrier is just not big enough or if the failure is coming out of a bad electrical design.
I’ve also heard that the Maytech remote sometimes brake if you use an usb charger with an higher output than 500mA.
@Eileen : Can you tell us more about your waterproofing trials for the second Maytech remote generation?
Same exact issue,
I had two of these remotes, I coated them with epoxy, and the other with regular primer spray paint. Both died after few charging discharging cycle with no reason.
The red light was blinking I couldn’t charge it. After two days it got working again. And then it got down forever
I prefer a good remote in a plastic bag to control my 5kw unprotected propeller close to my toes
I also had this remote and I didn’t modify it even though I knew it wasn’t waterproof. It died after the first water test but anyway it was faulty right out the box. While the trigger might be pretty good, I’m not sure if this remote is worth it. The overall quality is very cheap. Perhaps, there is another standard remote out there that’s of better quality and that could be modified to be waterproof.
1)For who long is your remote lasting?
2)Do you already have the “newer” version with the cable antenna on the receiver board?
3)Does you battery have that small circuit board for preventing over voltage?
4)Are you charging your remote with a regular usb charger?
Yes MT remote control seems still overpriced… I know this one is in the pipe line, real waterproof design for e-foil company but they told me they want to sell it to the crowd as well around 129$…looks awesome to me
The remote is running on 1s , you just scared me , I checked :1s
The one in the remonte has already silicone glue on it , it is hard to remove to make sure it is well done , so I prefered buy a new un protected and do that myself
