… yes, i know some poeoples wrote here about the troubles with that constallation.
I have too that constellation and sitting now hours and hours and not able to get a running configuration
I have a 12s12p Akkuconfig.
So, i tested a lot of different firmwares, lowkv totaly does not work.
Now i am around the Boat16S_V30
I changed a lot of settings (step by step) and got a working config where i get a smoth startup But the rotary speer was very slow.
So i change one setting, doese not work ( motor doese not spin)
I change the setting back to the original and, the motor does still not work.
What is going wrong with that firmware?
Yes, i do that since the first moment a lot of times…
Best results i got with the B_Uart_LowKvMotor but with that Firmwar ei can’t set the remote.
This process dose not work. But with the B_Uart_LowKvMotor the motor not starting, i always must push him. When he is running, i can controll him with the remote perfect.
Hello nice2cu, I have the same problem than you and my remote controller is totally different from yours. My motor is Maytech 65162 100kV, but the esc is the flier boat 400A 3-16S, I tried a lot of configurations of motor timing and nothing works.
Another think important, I tried with outrunner motor 80100 and works perfect.
I got to working him fine now.
I take a high startpower (70) and only in a small range of low speed he is little bit stuttering. In the higher range perfect.
But I still decide to buy a other one now…
I try the next configuration but I hear that when the motor turns, it is not a clean sound, how you said is a little bit stuttering
Flier 400esc. Firmware boat Boat16S_UV30_LowKvMotor with starting power at 70%. Timing at 5,
What firmware do you use?
