Blade efficiency is very important in a propeller. It’s a spinning wing that needs to generate lift. A paper airplane will fly with it’s flat wings, but you don’t see large planes with flat wings for the same reason.
And strength is another factor. If you made the whole blade as thin as the leading edge needs to be, the blade would bend or break under load. The root of the blade needs to be thicker.
You think melting threaded inserts would work? I’ve done this with PLA (like my nose cone) but I wonder if it’ll work on this injection molded plastic? If so, that would give you threads you could seal the bottom of as well. What do you think? Crazy idea or nah?
Would you share your cable specs between battery case and charger ? I know you are using 7 or 8 pins cables but I wonder which type suited for you. I will go with 15 pins for my pack.
I have tried a few different types. The ones I’m using now I am very impressed with. I add an o-ring, and fill them with silicone grease. I purchase them on AliExpress and with DHL shipping I get them in one week and it’s about $25 for two including the shipping.
Make sure to ask them to include the screw type covers. The rubber covers are not a good seal.
US $5.51 20%OFF | WS16 Series 9-pin Aviation Waterproof Connectors LED Power Cable Connector Male Plug Female Socket Rated Current 5A IP67 https://a.aliexpress.com/_mqKZNZ9
Thanks ! I’ve been ogling on Lift’s connector which I am about to buy too
Same one with 15 pins to balance charge with external BMS.
My question was more about the cable between this connector and the charger. I’ll be using a 15 or 16 x 22 AWG cables but seems pretty hard to find with silicon jacket. Which one did you use ?
I used 9 conductor wire and just pulled one wire out because I only needed 8. You could use this and just run two cables to get the 15, or 16 conductors you need. But, it’s not silicon covered.
Got a efoil surf session in this weekend. 5-7’ surf on the outer break…waves were traveling at about 22 mph. I couldn’t quite keep up with my infinity 84 foil. Next time the surf is big I’ll use the 76, or 65 wing. But, the small inside break was fun.
flightjunkie,
Thanks for this fantastic thread. So much good information and photographs. Good to see how much fun you are having. I have a few different wings, slingshot, lift and gong. earlier you said that you didn’t like the space skate. With a kite I found that I could make super sharp banked turns with that wing. Love the 84. I weigh 225 and have a lift 200 and 250, with the smaller stabilizer I can also turn much sharper.
Thanks again and happy foiling
Nice video. I imagine that you are just surf foiling when you drop the remote. I notice that your stance is very wide. That seems to work well for carving in both directions. Which remote did you use?
Flightjunkie, Post a video of you with the onewheel and gear headed to the beach. That sounds awesome. I have a one wheel but thought I would use a hand cart with big balloon beach wheels.
