Had a bad experience with the Flipsky 200A FSESC this evening. I made no changes in the VESC, same settings like 4 other sessions.
When I assembled my efoil, and put the board into the water, I tested the system shortly to check thrust, seemed ok. Turned off my remote to get ready to jump into the water.
Suddenly the board went from 0 to full speed in a second. I held the onto one of the handles, so the bord turning 180 right at my. Only When I turned on the remote again, the motor stopped.
In the Metr Pro record I Can see the ppm signal went from 1.5ms (center) to constant 1.25ms for up to 30 seconds. This happed 4 times, see below. Was really shocked.
Changed a ppm ramping setting after the incidents, and had a good session on the water afterwards:
Sounds like a pairing issue to me, I had exact same problem with an E skateboard, the board nearly went through a shop window until it hit a curb and snapped in 2.
Try re pairing the remote.
What kind of remote do you use? I have the basic nano remote and without setting the fail safe right it went crazy each time I would turn of the remote. Setting it right solved any issue and each time my safety leach gets disconnected now its stops properly
Thank you so much for your inputs! I just use a GT2B, modified in a smaller 3D printed case. I Will try locate the failsafe mode, og pair the remote again.
Thank for the link, I have manage to set up the failsafe now.
The only thing that worries my now is, that this hasnt been a problem before yesterday. Normally i was able to turn off the remote, When I fell in the water. So i am only like 50% sure, that this was the problem. Im godnat do some dry testing in my garden, the next couple of days.
