Flipsky 65121 motors (200€) in EU
For sale 1 used and 2 brand new flipsky 65121 motors. Sell it because not needed - we decided to use the more powerful 65161 motors.
Used: 170€ (cables are cut near the motor, you need to solder new longer cables)
New:200€
Spec:
  • Voltage range: 6-20S (25.2-84V)
  • Max power: 3700W; Continuous power: 2000W
  • Peak current: 100A;
  • Motor KV: 130KV
  • Size: OD65*L121mm
  • Shaft diameter: 12mm*m8
  • Max output torque:5.5N*M
  • Waterproof rate: IP68
  • Connectors:8mm plug
  • Weight:1.62KG
  • Structure:18N/P
Shipping from Estonia. Can send with parcel locker around EU for ~20€ probably everywhere.
We also sell comple efoils and DIY kits (Mast that you can build batteries into.
Instagram Ray Foil
Hi Ray,
Just wondering if you still have 2 brnad new 65121 130 kv motor. I m inFrance and want to buy 2.
I m the guy who is currently developping the BREMote followme mode for TOW + BREMote logs analyzer that will be live in few weeks.
Cheers
Jean
Hello. Yes we have motors availible.
Write e-mail please: hello@rayfoil.surf
thanks I send you MP
