Flipsky 7550 75V 50A ESC any good?
Anyone have used the 7550 ESC? How do you do make it waterproof, anyone have any experience with this ?
50A is not enough for an efoil, you will most likely not get out of the water with only 50A. That‘s probably why no one used it so far. Might be good for an eskate though.
It works for efoils, you can push it up to 2,6kw which is enough for Lift off, but somehow flipsky used bad components and FOC mode is almost unusable! Warranty & support is =0 so forget about it. Better get a tampa or maytech
yes, that is the product I checked,https://www.aliexpress.com/item/1005002428693323.html?spm=2114.12010615.8148356.2.13b44eb4E4YtJH
Do you have any link for tampa? Thanks for the answer
Yes its VESC VEDDER ELECTRONIC SPEED CONTROLLERS - Presented by TRAMPA
