I got a Flipsky Dual FSESC6.6 plus ESC thinking I could just put the two motor outputs together. OK I have no idea about this kind of controller either :-). Well, yesterday I configured it and that everything worked fine immediately. However, still with a 6384 (the 65161 is still on the way) and only one output.
Can I dare to try, connect the motor to both outputs and then drive the setup, or gives that defensively stress or with the CAN bus or even smokes me the controller off, especially later under load?
Actually unfortunate, because the values from the controller and also the switch and the telemetry are prefect !
What do you think?
olli
