Flipsky folding prop for 6384
I got it with the motor. Is it worth trying or I need to look for something better right away? Microsoft copilot trashed it. What works well with 6384?
works well. i use it and go up to 27km/u. with it.
I didn’t like them. Both the blades and the hub are very heavy.
Weight impacts performance?
Check out this link ! They have some good product…
6384, but how many kv?
80kv - go bigger
140kv - go smaller
Mine is 140 KV. I will check it out with Flipsky folding prop. Nothing to lose. If my build works, the next thing I want to try is a two motor setup. I will use 6384 to break from the water (in assist config, under the board) and at this point I will switch to 5085. I may need to print a folding prop for 5085. If you can point me to some CAD files I can edit in Fusion, it would be very helpful. 5085 came with a Flipsky fixed 4 blade prop, but I folding would be better.
