First time using VESC and currently only using the receiver PPM wires with Maytech receiver lower right and the USB for PC. The only instruction that came with the VESC is the diagram below. What are the other Flipsky VESC extra wirings for? Thanks.
The following diagram might help you. Itβs from @jeffM. (Efoil V3 post)
https://foil.zone/uploads/default/original/3X/1/7/17c7c1c0a9321744253154ec17cc82ca92dc486c.jpeg
