hello guys!
Few question about the flipsky 75200 vesc.
First one: there is no user manual when I receive it, can I find it somewhere online? Didn’t find it on Flpsky website.
If I want to connect multiple battery, they’re in parallel right? so if I want to use 72v 30ah I need to choose 3x72V 10ah?
The discharge current rating is the same, so if I have a continuous discharge current rated a 50 amp for one battery, It will be an addition, so 3X 50 amp= 150amps for the 3 correct?
But because I have a 6kw motor so I don’t need 150amps@72v, 100 will be enough. So I can choose 2x 72v 15ah. How I connect 2 batteries to 3 connector to have a good discharge repartition?
the last one, I see on the forum some of you usine passive cooling and some of you use a dedicate pump. Passive is more easy/light/efficient, but it give the same cooling quality or the pump give a good improvement?
Thank you very much for your help!
