Flipsky Prop Pin - serious fixing?
There is this pin on the standard Flipsky Prop. See pic. Sometimes it fell off while testing.
I am asking myself and the forum, if this is meant to be like this? There are for sure safer and more elegant and convenient ways to fix a prop.
How do you fix the prop?
Christof
I think hardly anyone uses this prop, it’s not so good.
The pin is supposed to be bent so it can’t fall out, cheap low power props sometimes has this solution.
A common pin for this type of prop :
