Hello, i Replace the flipsky remote through the erayfoil but i had only on and off. Its Not possible to Dose the movement of the Propeller. Any idea?
48v from the Akku and the Black, White, Red from the flipsky Bluetooth receiver.
If you have VESC, you could try to set up input wizard again… I think that would work…
BR
In Air or also in water?
I only try at Land, do you think it will be ok in water?
Maybe you have current mode?
There’s nothing to change available. I will See, what happens in the water.
The setting should be in VESC.
Other option is to callibrate remote.
Some ESC have different controll range of PPM.
I am really surprised, in water it works. There must be a sensor for this. Works good!
Thank you very much to all of you!
If you use FOC with current control, this is normal behavior as the current with no load will max out at some A (2-4A) and throttle is mapped between 0 and max current (100-150A). If you touch the trigger, it will accelerate to full speed. For dry tests you can change to duty cycle. I prefer current control as current equals thrust.
