Fliteboard battery teardown
Has anyone opened a flitecell? Pictures?
bump nobody? :wink: 20 char
This is the company that Flite, Lift and quite a number of vehicle manufactures have chosen to recycle their end of life battery products.
Not likely to tell anyone else how to open the Flitecell but interesting factoid anyway.
I am building a battery for a DIY efoil and want to use the same terminal posts as on the Flitecell can anyone tell me if they use a 5.7mm post or 8mm post Amphenol Surlock connector.
if this is still relevant, Amazon has connectors like those. They are for linking rack mounted batteries in solar backup systems.
Could you share a link?
Here’s one that is good for 60 amps and has solder connections. They also have screw terminal connections. Amazon.com: 1 Set Battery Energy Storage Connector, Quick Plug Terminal High Current Connectors Right Angle Plug and Socket IP67 Waterproof Power Connector Stud Wiring Method 60A 10mm² (60A, Orange) : Electronics
Many members including Mantafoils used these Amphenol 1KV 120A SURLOK PLUS SERIES one in 2020
'Battery case for DIYers - #32 by Mantafoils
by the way, amphenol connectors compatible with my casing for reference:
plug black
plug orange
socket orange
socket black
