Fliteboard Motor KV?
Does anyone have an idea/guess of what KV, pole count, motor size Flite would be using to be able to accommodate both prop and jet?
Thx!
It’s not a true jet. Its a standard propellor in a full shroud.
100% but curious on the motor KV they use (100/120/150/170kv) to support the prop and the tiny inducted prop to still have torque and efficiency between the two.
I think the Flite has a gear box (assume a small planetary one) so the kV of the motor isnt that relevant since it will be reduced.
I’m not sure why they went for a gear box, seems an unnecessary complication. Maybe no lower kV motors were available when they starting making them.
