We have a severely unbalanced battery. The BMS is not balancing the battery for some reason. Together with technical support, we performed the “Flitecell” update, but were unable to achieve the desired result. Does anyone have enough knowledge about the BMS installed in “Flitecell”? The following questions are of interest:
- What is the balancing algorithm? For example, does the BMS balance exclusively during charging or discharging?
- How is energy distributed during balancing? For example, does energy flow from the most charged cell to the most discharged one, or does the BMS discharge the most charged cell, releasing energy as heat?
- What is the balancing current? How much current can each cell draw during balancing?
