Are you in the States? I can ship one to you. The vent.
Hi! I am in washington state. And that would be very generous of you!
@Vincentbraillard. Thank you for the link.
I hope this will help vent the heat from my battery pack.
Hi @V_S
I did some paper trail research and I found out that my cells are 21700 and rated at 5000mah.
That makes sense.
But i guess 5AH only in paper. Usually they have 3-4AH (21700)
Hi Mauiman,
You will share files of 3d printed files of this jet drive set up?
Giacomo
Yes eventually after I get it working.
Really impressive. Nice one
Wishes for your child, but the jet child is growing?
Thanks! yes, the jet child is still growing. I had to design a new motor mount because the previous one was too short for my shaft coupler and sealed bearing so I decided to move the coupler to the outside of the motor mount.
Nice video, which drone is that? But you are not using your jetdrive, correct?
I am using the Airdog. But the lowest it can fly is 5M. I have to use the mavic if I want a low flying water shot.
Correct, no jet drive yet. Waiting for a free weekend to assemble the new motormount.
Excited to see how it runs in the water!
Would you share your impeller as .stp file? I downloaded already the .stl file. I want to try your impeller in my propulsion, but i need to make a modification for the mounting screw. Fusion 360 can not convert the stl
Sure! I will convert when I get back in town.
Looking mint! Good luck for your water tests.
It looks like your carbon mast is hollow? Where did you get it? And have you tried riding this wing yet?
Looks very similar to the Chinese carbon fiber wing I have. Most sellers offer hollow mast as an option.
US $480.00 | 2019 Top Quality Foil Surfboard 3K Carbon Fiber Hydrofoil In Surfing
https://a.aliexpress.com/tzJo7t3i
