Yea unfortunately im a big lad so its more about keeping the current down for me. Are you going to have some sort of external heat sink? My first approach was to have the esc mounted inside but I wanted some external cooling so thought I would put the esc’s claimed waterproofing to the test.
I’m still throwing ideas around.
I do really like the idea of external esc. Partially because I’ve seen a lot of escs blow up and don’t really want the battery to go too. ![]()
Yea 600 - 1000 degree fire on my back scares me haha.
I got in touch with the Peli sales rep for the R60 3D model… Got told that you need an NDA… When they already have 80%+ of their products with 3D models readily available for everyone to use…
Ended up selecting a CamdenBoss (CHDX-325C) as it is made of ABS and has more usable space for the same footprint. Plan is now to use 14S3P vs 12S4P (I’m a big lad too), no BMS, with a Sequre WP14200 stuck outside.
Yup pelican told me the same. Interesting choosing the ABS over the polycarbonate. Is that due to wanting good adhesion? If its going into a belt rig I guess it will be covered so UV wont do much damage.
Yup, I went for ABS so I can “glue” 3d printed ABS parts to hold the esc and wires or even latches protection…
My only concern is finding a neoprene cover big enough now…
A bit slow on the updates here but have got something workable. Tested once and only had motor amps set to 50a so was pretty insipid. We now have massive storms so not ideal testing at the moment.
I’ve used the aliexpress selfie belt mount and bolted a carbon plate to that. Used velcro for the interface to the box and wrapped a camlock strap over it for extra security.
Coiled cable is from aliexpress, wing leash running though the centre.
I’m now looking a making a shorter motor pod mount. Also really need to move to code foil profile.
Same starting point, slightly different layout. Got a couple working prototypes. Currently tweaking files for ease of assembly and standardization so all batteries are compatible across the boxes i’m putting together. Should be ready to share files and build list shortly.
Be amazing if this box/battery design becomes a but of community project.
Oh wow. This is looking tidy! Interested to see how this pans out.
This looks really nice @MDHD. I’ve got one of these R60 cases as well I am working on. Interesting you are putting together so many. Seems like you are attaching it to a Duotone belt?
How did you manage to design that part to fit so nicely to the geometry of the box? 3D scan? Or did you manage to find a CAD file for the R60? I would be a bit concerned it might crack with the part that extends up along the sides of the box. Maybe some carbon rod inserts can help?
Perhaps some Velcro between the box and printed part may offer some extra security?
Hi!, I´m building mine with the same Flipsky waterproof ESC, but never thought to leave it inside the box. How did you solved keeping it cool? Nice work!
Carbon fibre plate on the bottom, m4 screws through lid fillets both increase compression of gasket and secure to mount.
Never had failure on the perpendicular. I use short cord from box to leash attachment in case. Instead of carbon rod I would use threaded rod full length, this would both increase strength of stems and pull out resistance over the threaded inserts currently used to accept m4 from lid fillets.
Would just glue the printed mount to the bottom of the box. Could design channel in mount for 25mm strap as failsafe if you felt necessary.
You got any pics of your layout? Be really nice to see some alternative ideas for the box before I finalize design.
Keeping everything internal with a 12s3p left me pretty limited options RE ESC. Thinking about an external ESC or designing aluminum profile with 360deg lip to raise lid and house ESC.
Could fit 42Cells in current design if you strip the internal rubber from shell as this allows you to go to block layout.
Work in progress but here’s how my 10s3p looks with Flipsky Vesc.
Thinking I’ll probably do another version with the waterproof Vesc on the outside.
Afraid I can’t offer any insight battery-wise. I have a pair of 15ah “solid state” Racepow packs. So no 21700 cells.
I’m planning to attach my waterproof 150A vesc to the side of the box. It happens to fit well between two of the ribs on the outside. Just had to use my dremel to shave off about 1mm of thickness on one rib to make it fit.
This is my current setup, but I’m looking for a neat way to connect the three phase wires to a single connector. How would you do it? I’d like to avoid using three separate bullet connectors.
That’s how I did it: Daniels assist (3rd build)
3 5.5mm bullet connectors in a diys housing.
