Foil gear database
Hi guys, I tried to sketch out on a website a compilation with the data of each brand and hydrofoil line and some of their technical aspects. I hope it helps someone. I don’t know if I forgot any brand.
I added a tab for English, but the original language is Portuguese/Brazilian
MODEL COMPARATOR
When you select 2-4 models in the checkboxes, a “Compare (X)” button appears, opening a modal with a side-by-side table showing:
✓ Wingspan (cm)
✓ Chord (cm)
✓ Area (cm²)
✓ Aspect Ratio (AR)
https://lovable.dev/preview/kr5ptuTTXkuhqi1FV22ec7aBWCSejLfw
brgs
Eric
Hi Eric, thanks for building this foil database. I found it really useful for comparing front wings. The Lovable preview link now shows ‘not found’. Did you move it to a new address? I’d love to use it again. I’m also interested in comparing boards (size, volume, outline), so if you ever add those, count me in. Cheers, Yannick
