Selling faux drive, perfectly working, used 10 times.
Shipping in Europe, based in Italy
Battery Module (500€) including:
BATTERY - BMS - REMOTE - VESC - DRYBOX - RACK - CHARGER:
Battery with 52 (13s4p) cells:
Tenpower INR21700-30SG 3000mAh - 30A
Able to delivery peak 120A (48V - 560wh)
BMS in charge and discharge:
JBD Bluetooth Smart BMS 13S
120A (with 360A peak) Monitorable via APP
QS8-S antispark connectors for battery
VESC and charger.
Flipsky VX5 Waterproof remote
with recevier configured with VESC via UART
with box, wires and warranty on banggood.
Flipsky 71200 VESC (84V)
with aluminium case and heat sink
already paired with remote and battery
VEVOR Drybox with 3 waterproof connectors
for motor cables for quick plug
and hole for quick mount on board rack
Board rack for the drybox compatible with
Gong and North boards, easy custumizable for toher brands
48V Battery charger coming with the QS8 adaptor
Motor Module (500€) including:
MOTOR - MASTMOUNT - PROPELLER - GONG FOIL v2
Flipsky 6384 used 10 times, always washed with fresh water,
still on warranty with flipsky, covered with epoxy resin, CorrosionX treatment
2 blades foldable flipsky alluminium propeller
3 blades flipsky alluminium propeller, already mounted
quick realese mast mount from kparts-watersport with strap
coming with 2 straps: black (hard mount) and orange (quick mount) -
3D printed e-foil mast mount compatible also with Flipsky 75100 family (not included)
Gong allavator Foil v2 with Alluminium mast and carbon front wing and stab.
Front wing is Curve M-T 73 with 1150 square cm surface.
Foil in optimal condition, coming with screws and bags, ready to go.
All setup ready to go.
Buy togheter save 100€: 500 + 500 = 900€
I can show working demo on live whatsapp call for any doubt.
More picture in DM
NOT SELLING THE BOARDS
Cheers everybody
