Hi everybody, after a lot of prototyping and testing in all conditions of water, we approved the best solution of folding propeller for assisted drive based on the 6384 motor 120KV/150KV.
I made a carbon fiber version by molding and the industrial production by mold nylon injection (made in Italy)
Specifications:
This is the question that opens the discussion on my remote control system, which records all vesc data in its memory and gives me the possibility to analyze the data post rides.
In the graphs below you can see rpm in blue and power consumption in watt from the battery in red. On the x-axis, the number of seconds of the ride (ride time about 30 minutes).
In this ride there are 4 take off and several pump times or wave ridings. The system can measure each time.
This is not the ride in efoiling. Consider the same power and rpm during the motoring phases.
