For sale: motor mounts for Gong V2 mast and 65xxx (Like Flipsky 65161)
We (my dad and I) have some Gong V2 mast and 65xxx (Like Flipsky 65161) motor mounts left for sale.
They are designed to fit the Flipsky 65161 motor, but any other 65xxx will (should) fit too. (you might need to do some additional work to make other motors fit!).
Weight: ±115 grams
Aluminum used: 6082
Anodized: Black
Price: €120,- (Discount available when ordering a All-in-one Fliteboard (Series 3) to Gong V2 mast or V3 plate adapter )
The price above does not include shipping costs!
Please send me a PM if you are interested!
awesome work …seems to make quite a hole in the mast …pls share a photo without the support so we can see the hole . the cover on top of the support is alu or 3d printed ?
Some pictures of a modified mast. (And needed cut)
This is done with a CNC, but easily doable with a file.
The nose is 3D printer with PETG-CF (CF not needed)
The mount has been teste a lot this season (including in races) with no issues whatsoever.
Unfortunately, our CHC doesn’t reach high enough, so we had to CNC the mast lying flat.
Because of this, we still need to use a small file to finish the 90° corners.
It’s a one minute job.
Results:
hello seems clean …did you try on 6384 flipsky motor too ? I can use a plate to adapt the holes / will send you DM to buy one or 2
Not sure about the 6384 . Do you have the pattern for me so I can have a look.
a plate to adapt will always work. You even have some room in the plate itself to drill holes.
Yup will build a plate . Share your details since your profile is hidden so I can get the mount
Maybe I am misunderstanding this? My profile is hidden?
If so. How did all other users get in contact with me?
send me dm because i can t …profile hiden ?
Wow I found it. It was hidden. So how the hell did all the other users PM if this was on? Is this something new? I never touched it!
hide
