Melted down. Given we were pushing it but the standard neugart setup could handle the load we were applying and this could not, Happened very quickly as the motor unsynced and cooked.
can u tell us which is the ESC that u use ? no hall sensor on his motor, i can imagine ?
Castle talon 120 hv there is no hall sensor
Is it from Reacher Tech, the manufacturer of the motor ?
What did they say when you described the problem ? Is there some kind of warranty ?
@Martin.martin How did it go? Does it work?
Hi all
Need some help
I am trying to test my setup (useing tape I no)
All I’m getting is a beep about a second apart instruction say esc unit saying wrong power had a old drill battery I am using 18v is this the reason??
What type of ESC?
The drill battery is roughly 4-5s equivalent so it should be no problem. I’m assuming the battery is fully charged…
If it is the same software as the flier ESC’s, set the battery cell count to auto and it should fix it, I had a similar problem with my 400a boat model. Do you have software on pc or program card?
@Martin.martin have you any more luck testing this motor?
i’m torn between the 70120 and the ReacherTech or MayTech but obviously the expence of the latter two is playing on my mind wiht a battery yet to sort.
Have you it tested yet? Any thoughts?
Go for either the reacher tech or maytech motor. They are better options.
