Fr 2019 motor system
I have the folding prop.
I think I’ll prefer folding over 3 blade (I haven’t tested them yet. Still working on a board). But, yes. You could make the 3 blade prop fit the 65161 motor just as easy.
No. I haven’t done it. But I took some measurements.
The smooth part of the shaft is the same. The threaded part of the shaft, and flange depth is different.
All you have to do is drill out the hole in the prop (where the threaded part of the shaft goes) with a 5/16" bit then use 18mm wide shim (washers would work fine) so the nut tightening load is on the flange and not the pin. And depending on how big the nut is, you might have to drill out the indentation for the nut.
Looks easy to make Lift/FR props fit the 65161 motor.
But, once modified it will be a bit harder to use this prop again on the Lift/FR motor. Now you would need a sleeve for the bolt that holds the prop on. Probably have to make this sleeve. That’s why I haven’t done this mod yet.
I already have one of David’s 3 blade props for the 65161. So, at this point I don’t need to do this. If I want to put a folding prop on a 65161 motor, this is how I’d do it.
:call_me_hand::beers:
