@Flying_Rodeo How can I order 2 for reacher motor? Can also order custom shaft to fit it for PM setup?
I would like 1 for a Maytech motor. Gold or Black please…
How do I give you an address and some money?
I will inform you all when its gona be finished
Hi David,
What are the characteristics of the batteries and escs suitable for your engine?
Giacomo
At least pics at 130A for the motor and true constant 60A for the battery side at min
150A esc will do the job , so may be written on the box 300A ?
Arc 200, a200s , trampa …
Alsoe mgm, kontronik, yge ( i recomended all there over 160a and you will fly with no problem)
I will be happy also get red and gold. Will also try on 6384 setup.
@Flying_Rodeo, I’m also interested to purchase a black prop for 100kv 65161 motor. Looks great
100kv Flipsky, two in blue please.
Regards
Jan
2 please. Any color is ok.
Same for me please. 2 any color is ok.
Do you also make 6” pitch ? I would then rather take one 6” and one 7”.
Going to see how they perform on APS direct drive 80100 / 130kv.
No refund needed if it does not fit my need.
@Flying_Rodeo I’m interested in some props for a flipsky motor. Gold and red if I can pick the colors.
@Flying_Rodeo I’m in too if it’s not too late ? Would love to test it. Two black is possible ?
It’s to test with Flipsky. Give me the paiement details…
yummy
20 characters 2
Moving closer to the hub of a boat prop I see…
Hey FR, have you measured the efficiency gain of this added saucer creating a adhoc vacuum bubble behind the boss ? Say at 20, 30 and 40 kmh what are the amps drawn without and with this detail ?
its almost same BUT its feelll so smoth.. 0 NOISE / 0 VIBRATION / 0 CAVITATION
SEXY!
I am wondering about the dimensions of the front of the prop.
I would like to start designing the hub that sits between the prop and motor. Can you give any dimensions to help?
♂:dash: fly FAST
