Edit : it’s 12mm for anyone wondering, coz Flipsky is now offering 2 different versions, one 10mm and another 12mm shaft.
Count me in, please.
Hello… ok we have more then 10 buyers
I will start with a production…
I will lett you know when its finished and im gona contact each from you
Props its for threded flipsky shaft
Yes
why you need another one
When it is the same one not
Or you make me a special prize
I would take one too.
Greetings and thanks frank
1 for me too 12mm for flipsky.
+1 for me. Can’t wait!
I will take one as well for the flipsky 62151. Thanks for helping the community David!
Do you need order via PM or you will come back?
no, i need 2 weks for finishing
and then send off
Hi, can i buy mast clamp from you? Thanks
I want one too. How much pitch is it? Can we choose?
This its 6 inch
Perfect in eficient and speed…
One for me also?
Thanks!
at 100kv with 11s I probably need 7 pitch, I believe FR also has a 7 pitch prop.
Hey David, I am also very interested but I have a custom shaft setup and afraid in might not fit
Can you tell me:
-hub length
-depth slot where pin is placed
-required shaft length from pin to securing bolt on threaded part
-distance from pin position to back-end of motor pod
so I can check if it fits on my setup. Hope you have time for this. Thanks!
Hello, prop its made for flipsky shaft… the beast its look flipsky drawing…
