My Dream was to wake on my
river.
Go electric ![]()
Is that Lift Efoil board with one of your custom motor pods attached? Thats ingenuous. How much run time do you get towing a wake board?
Two halyards are used for control, perhaps the motor plate can rotate?
It’s probably enough to just pull on the back corners of the board to move the front.
You’re right, if you look closely, you can see that both tow ropes are fixed at the edges of the board.
No, this its not lift board its FR board.
Wake bord time with 68kg rider 30 - 40 min with Lift big battery.
But if you pull surfboard with foil then you stretch to a 90 min:pray:
very nice! Looks like you’ve nailed it.
