Hi all, I have been working on a tow bougie, and starting to get my motors and controllers up to speed. I have been using VESC tool on Mac ver 3.01 to do the VESC config. I have a couple of other VESCs from Flipsky, and have had no issues getting those to work with the 65111 motor. I did the FOC wizard, then used the arrow keys to control it with current and see it spin (to keep it as simple as possible).
I then started trying to use the 65161 with the FSESC75200, I did the wizard, large in runner, 6S battery (for testing), 6 poles. During discovery the motor spun and seemed to work just fine. When it was done I tried to use the arrow keys to test it, and it didn’t work. If I touch the motor I feel something slight happen when I press a key, but the shaft doesn’t move.
I also tried the 65111 on the FSESC75200 and had the same result.
Any ideas on what I might be doing wrong?
Thanks!
Scott
