It’s not effektiv!!!
You need a cleaver Prop from RC boats and drill it for you Stator.
Greetings Frank
Thanks! There is no mast, the pump is integrated woth the board, under it and in the back.
what do you mean its not effective? I’ve tried it at “low” rpm’s and it seems pretty effective for me.
Got the new stator and impeller, at last i’ve gone with the 80mm version. 55mm for comparation, also a 6 bladed vs the old 3 blade. Now just to find someone who can print the housing at 290mm, and not ask a fortune lol
So a tube goes down?
i am planning to build a gas powered foil too
pls share
cryss
Any progress/updates on your build?
Hello David…
Im from croatia to.
Thare is for of us here on forum.
If you wanna i can add you to our croatia efoil group on whatsapp.
