I am Andreas and I want to build an efoil with the slingshot windsurf foil fwind 1 (we have one).
For the first tests, the windsurf foilboard slingshot dialer 130l will be used, then it is planed to switch to a DIY board with integrated electronic box etc.
The propulsion system will be near the one of pacificmeister.
So I decided to make the gearbox by myself, it is planed with a ratio of 4,5:1.
The pinions on a test plate and the printed pinion to the prop.
If it is not stable enough, i turn the steel pinion to the correct diameter and screw it on a milled holder.
I think that the plastic pinions should be good enough, they have modul 1, that means big teeths an there are used three ones around to share the load. Most load is on the center pinion, it is steel. The gearbox is not used daily as a machine, so the wear should be acceptable.
It is finished so far, but I will need some more time to build the rest around before making water tests.
That’s a good idea,
there could be used countersunk-head skrews , too.
I dont’ know if it’s really an aerodynamic problem at the relative low speed, the hydrofoil will do but nevertheless, it looks better.
Yes,
I think it won’t be stable enough, not even when build in PA 6, what is much more stable than PLA etc.
The one problem is the load on the very few teeth, the other is the fixation on the motor.
But there is no need to build it by yourself, it is cheap and available with the correct diameter inside.
the step and stl files and a list of material will be posted here in the forum, give me a few days.
All the gears are from www.maedler.de, the order numbers will be added to the list of material.
If the printed gear gets too hot, there is a plan B.
The metal internal gear shown in post 2 will be combined with a base made from PA 6 or POM to a composite solution. In this case, the metal gear has to be turned down outside and there have to be drilled some holes for the connection with the base.
Best Regards
Andreas
P.S. It’s a little difficult for me to do this in english, please excuse me and correct if I’m wrong.
