Hi. I started to build the drive train now. As I had SSS56114 and an Neugart Ple40 1:8 in the drawer I went for geared setup. As I wanted it as short as possible I decided to replace the motor front shield completely. The sungear has a ball bearing which I used as front motor bearing. The new front also has the mount for the ple40. I printed it, but when it works I will machine it from AL. The motoshaft needed to be ground to 8 mm to fit the clamping of the sungear.
