Gerland Efoil for Maytech Remote Control Parameters
I have a Gerland E-001 efoil with a Maytech V3 remote and 58V / 53Ah battery model (G-E053LBT). The motor is marked GEA303 at 8K.
The remote arrived configured as an Eskate, so I’m trying to make sure I have the correct efoil parameters. I have changed the throttle mode to Surfboard , and the throttle is working correctly with the motor/ESC.
The settings I am currently trying to verify if I set up correctly are:
  • Battery: 14S
  • Cell type: 3.7V (other option is 3.2V)
  • RPM/Data Source: MTSESC-WP32
  • Motor Pole Pairs: I don’t know what this should be
Does anyone have this same or a similar Gerland/Maytech setup and know whether 14S / 3.7V / MTSESC-WP32 is correct, and what the appropriate Motor Pole Pairs setting should be?
I’m mainly looking for someone who has the same hardware and knows the correct parameters. Thanks!
So if anyone does need this info the values are:
  • 14S
  • 3.7V
  • MTSESC-WP32
  • 3 pole pairs for the 8K motor to display RPM
Hope that helps someone in the future
